Activity Forums Adobe Photoshop cannot save EPS file as anything but photoshop raw or TIF
  • cannot save EPS file as anything but photoshop raw or TIF
    Posted by Matthew Chapman on August 20, 2006 at 3:53 pm
    Hi, new to photoshop, which i probably shouldn’t be. A client gave me an .EPS file which has several of their Icons on it. i can open the file in photoshop, and choose a resolution (i am using 3000 pixels) and then PS rasterizes it. I then need to be able to save these back out as a PNG with a transparent background, but have not been able to as the only options it gives me are to save as a copy, either RAW or TIF. i have been able to save out with other files but not this one…
    help?
    thanks
    matt chapman
    Tim Kurkoski replied 20 years ago 2 Members · 2 Replies
  • Matthew Chapman
    August 20, 2006 at 4:39 pm
    as a follow up, when i open the file with only 200 or 1000 pixels it will let me save out
  • Tim Kurkoski
    August 21, 2006 at 6:43 pm
    3000 dpi is a HUGE image. The formats you’re choosing may not support resolutions that high. Use the Image Size dialog to control the image dimensions if you must import at 3000 dpi.
