Cannot render a specific project (worked fine yesterday)?
Hi
I’ve got a pretty large project with multiple Trapcode Particular Layers. Yesterday I started rendering it in JPEG-Sequence it worked fine. Today AE doesn’t render a single frame of this project, no matter which format I try… Other projects work fine. The problem only occurs with this one _and_ its older versions/backup files.
AE rendering starts then stays at “Time elapsed 3 seconds” and no rendered frame for hours. It does not freeze, just stay this way.
I searched the web and am still clueless… and would be thankful for any advice.
Greetings,
DominikHere is the log:
Adobe After Effects v11.0.2 (Windows 64) render log for project “Cloud 11.aep”Rendering started on 14.10.2013 at 20:02:05
14.10.2013 20:02:05: Starting composition “01 RENDERE ClOUDS STRAIGHT”.
Render Settings: Best Settings
Quality: Best
Resolution: Full
Size: 1920 x 1080
Proxy Use: Use No Proxies
Effects: Current Settings
Disk Cache: Read Only
Color Depth: Current Settings
Frame Blending: On for Checked Layers
Field Render: Off
Pulldown: Off
Motion Blur: On for Checked LayersSolos: Current Settings
Time Span: Custom
Start: 00115
End: 00230
Duration: 00116
Frame Rate: 25.00 (comp)
Guide Layers: All Off
Skip Existing Files: OffOutput Module: Lossless
Output To: F:Jpeg AE Render1 RENDERE ClOUDS STRAIGHT_[#####].jpg
Format: JPEG Sequence
Output Info: -
Start Frame: 115
Output Audio: -
Channels: RGB
Depth: Millions of Colors
Color: Premultiplied
Resize: -
Crop: -
Final Size: 1920 x 1080
Profile: -
Embed Profile:Post-Render Action: None
Render stopped by user.
14.10.2013 20:31:15: Finished composition “01 RENDERE ClOUDS STRAIGHT”.
Total Time Elapsed: 3 Seconds
Log closed on 14.10.2013 at 20:31:15
