Activity › Forums › Adobe InDesign › Cannot open file?
  • Cannot open file?
    Posted by Runess on September 20, 2006 at 3:16 pm
    Hello everyone, i have a big problem, so i hope you can help me!
    I’m doing a DVD Cover, in InDesign, so i surf around the web serching for templates, and find one. I’m quite excited, because iv’e been looking everywhere for a template!
    Then i open it and then inDesign pops up with a info box called: “Cannot open file”, then it sais “Content manager”. Under that they writes:
    “Cannot open DVD Cover_tryk.indd”. Please upgrade your plug-ins to their latest versions, or upgrade to the latest version of Adobe InDesign.”
    Iv’e tried searching for updates, and it didn’t find any! And i don’t want to upgrade software!! Quit expensive!
    Is there anything i can do? Iv’e had this problem before, and it is quit annoying!
    So do you guys maybe know some plugins, that solves teh problem, or a way to update. I just clicked Help -> Updates, and it said no updates, but there must be some way to solve this!
    Thanks in advance!
    Best regards Rune B
    Best regards
    Erica Gamet replied 20 years ago 4 Members · 4 Replies
  • David Hamuel
    September 20, 2006 at 11:49 pm
    > I’m doing a DVD Cover, in InDesign…
    Version?
    Did you try Adobe.com?
    Your Ultimate Source
  • Runess
    September 21, 2006 at 9:02 pm
    Hello!
    I use InDesign CS…
    I have tried Adobe.com, but their plug in, only opens cs2 files if they are exportet in *.inx
    Best regards Rune B
  • Bj Ahlen
    September 22, 2006 at 3:35 pm
    If you don’t have somebody nearby with CS2, e-mail the CS2 .indd file to me at bja7777 (at) yahoo (dot) com.
    I’ll convert it to a .inx file you can open in InDesign CS (assuming you have the free Adobe plug-in for this).
  • Erica Gamet
    September 24, 2006 at 5:40 pm
    Did the .inx file work for you? If you have InDesign CS and want to open a .inx file, you don’t need a plug-in, but you do need to have the right version of CS. It needs to be 3.0.1 April 2005 CS2 compatibility update. If you don’t know if you have that version (since on the surface it will say just 3.0.1 and you might not actually have the 2005 update) do this: hold down the Command key (on Mac, ctrl on PC) and choose About InDesign from the InDesign menu. The full version should read: CS 3.0.1 (838). If you don’t have the (838), download the compatibility update from adobe. Hope that helps…
    Erica Gamet
    Digital Dimensions
    https://www.digi-wizard.com/learn
    “…for there is nothing either good or bad, but thinking makes it so.”
