Activity Forums Apple Final Cut Pro Legacy Cannot make multi-clip-frame sizes are different
  • Cannot make multi-clip-frame sizes are different
    Posted by Walter Coles on May 18, 2009 at 9:54 pm
    I am using two angles to make a multi-clip for editing in FCP. Cam 1 is a Panasonic HVX200, project is recorded on DTE Focus FS-100 in DVCPro HD 1080I/60. The frame size of captured clip is 1280 x 1080.
    Cam 2 is a Sony HVR-Z7U, project is recorded on Memory Recording Unit HVR-MRC1 to a 32GB RiDATA CF card in HDV 1080i/60. The frame size of captured clip is 1440 x 1080.
    I synchronized the clips, clicked on the icon to make a multi-clip and got a message that the multi-clip could not be made because the frame sizes were not the same. How can I fix this problem?
    Adam Chesbrough replied 15 years, 6 months ago 5 Members · 14 Replies
  • 14 Replies
  • John Pale
    May 18, 2009 at 10:17 pm
    Convert the footage in Compressor to match.
  • John Pale
  • John Pale
    May 18, 2009 at 10:18 pm
  • John Pale
  • Walter Coles
    May 18, 2009 at 10:45 pm
    this is my first time to use this forum; I hope I’m doing it right. I converted the 1440 clip to 1280 but got choppy footage as a result like every other clip is missing. Should I go the other way and convert the 1280 clip to 1440?
  • Shane Ross
    May 18, 2009 at 11:29 pm
    Ignore John…he is wrong. You need to convert the footage in Compressor to match.
    (lol)
    YOu cannot make a multiclip with two different formats. The formats must match exactly. So you need to convert one format to match the other, and it would be better to convert the HDV footage to DVCPRO HD rather than try to convert the DVCPRO HD footage to long GOP HDV.
    Or convert both to ProRes.
    Shane
  • Shane Ross
    May 19, 2009 at 12:39 am
    Do you have differing frame rates? 23.98 and 29.97?
    Did you use Compressor and the Advanced Format Conversion settings?
    Shane
  • Walter Coles
    May 19, 2009 at 12:45 am
    Thank you Ross and Shane. I am converting to DVCPro now.
  • Walter Coles
    May 19, 2009 at 12:49 am
    Frame rates are the same 29.97. Yes to compressor advance settings.
  • Shane Ross
    May 19, 2009 at 12:56 am
    [Walter Coles] “Thank you Ross and Shane.”
    JOHN and me. I am not two people…although there are rumors…
    Shane
