Activity › Forums › Apple Final Cut Pro Legacy › Cannot make multi-clip-frame sizes are different
Adam Chesbrough replied 15 years, 6 months ago 5 Members · 14 Replies
John Pale
May 19, 2009 at 4:03 amWhoa. I see my response cloned itself…glad it seems to have worked out.
Alex Arndt
August 6, 2010 at 7:06 pmIs there a way to convert a misproportioned angle to the same proportions as the rest of the angles without squishing the shot? As in, can you just leave the top and bottom black and not squish the frame and then use that in multiclip?? Thanks so much!!!
Adam Chesbrough
March 8, 2011 at 4:15 pmDoes it matter if one of the clips is ProRes 422 while the others are ProRes (LT)?
macbook pro 17″ i7, 8GB RAM
esata external HD 7200RPM
canon 5D mark II, 24-70mm, 50mm, 15mm fisheye, juicedink DT454, zacuto striker
