Activity › Forums › Apple Final Cut Pro Legacy › cannot launch FCP3 in OS X. Why?
  • cannot launch FCP3 in OS X. Why?
    Posted by John Graves on August 30, 2006 at 3:22 am
    My main harddrive contains both OS 9.2.2 and OS 10.3.8. When I try to launch FCP 3 from within OS X it starts launching OS9, then it says:
    “Aurora Igniter INIT Error”
    Aurora Igniter hardware or driver not found error
    and it also says (in OSX)
    That application or control panel is not supported by classic.
    I know I have igniter drivers for both OS9 and OSX. Since my FCP3 runs fine on my OS 9.2.2 but not OS 10.3.8, does anyone know what setting or correction might be made to be able to run FCP3 in OSX??
    thanks a lot
    -avantis
    “Life is good, as long as it doesn’t take up too much of my time.”
    -anonymous gamer
    John Graves replied 20 years, 1 month ago 3 Members · 3 Replies
  • John Pale
    August 30, 2006 at 8:16 am
    It cant run in OSX, its a classic application. FCP cannot run in the Classic Environment, you have to boot from an OS9 System Folder.
    You need to upgrade to FCP 4.x or 5.x to run in OSX.
  • Ben Holmes
    August 30, 2006 at 1:25 pm
    FC3 runs in 9.2.2 or 10.1.1 onwards. I think it may be the last version of FCP to support OS 9. Didn’t the install disc come with a version for OS9 and one for OS X?
    Check your install disk – I doubt it’s the same install for both OS versions.
    Ben
    Editec Broadcast Editing Ltd
    EVS & FCP specialists for live OB operations.
    “The Supercar Run” now available for international distribution from http://www.electricsky.com
    See you at IBC – we’re there with our FCP/replay truck…
  • John Graves
    August 31, 2006 at 2:39 pm
    Yes I do have an OSX version on my FCP3 disk, but it wouldn’t install. Thanks for the suggestion, I will try again.
    regards
    John
    -anonymous gamer
