Activity Forums Apple OS X cannot in install os x tiger
  • cannot in install os x tiger
    Posted by Mark Schneller on June 6, 2008 at 2:30 am
    I have a G4 Powermac 500meghz 1.5 ram (APG) sawtooth , I try installing tiger on a newly partition drive that was verified and repaired in disk utility. The install dvd will load base system 1 ok but half way to installing the essentials in stops responding. and gives me a message ….. errors installing software, try
    reinstalling. any advice
    thanks, mark
    Rainer Wirth replied 18 years, 3 months ago 2 Members · 3 Replies
  • Rainer Wirth
    June 9, 2008 at 12:28 pm
    Either you have a bad RAM chip (test it with Tech tools Pro) or your HD has bad blocks.
    I guess a Ram chip. If you test it with tech tools you have to read the test descriptions! The computer starts directly from the DVD:
    Rainer
  • Mark Schneller
    June 10, 2008 at 1:18 am
    Hello Rainer
    I solved the problem.. One of our forum buddies suggested that I strip out all non APPLE
    hardware. So I started with the adaptec scsi card that drives may Nikon scanner. THAT
    WORKED.. although it was purchased though other world computing(mac supplier) and has mac adapter written on. I think it may of failed (only a year old) it does not show up in the
    scsi field in ABOUT THIS MAC. The ram could be another issue, I have 512 of apple ram that came with the G4 and purchased 512 of non apple about year ago . In the memory field it
    shows all ram to be ok, Should I trust this information? Any way I was able to install tiger on
    both my hard drives with out a problem and every thing is working fine. I really appreciate your advise… Guys like you make this forum work.
    all the best and keep posting, Mark
  • Rainer Wirth
    June 10, 2008 at 4:26 pm
    sounds good, at least you could install the system. No, the buildt in software is not enough. I’ve had this problem and even had to read the reports from tech tools pro to detect the fault. Tech tool also checks your system. My system did work, but not properly. Now my whole system works faster and more reliable. It’s worth buying.
    Rainer
