Activity Forums Apple Final Cut Pro Legacy cannot import local qt exports….why?
  • cannot import local qt exports….why?
    Posted by Bob Flood on January 6, 2006 at 4:50 am
    Hi Again
    I have downloaded several stock footage demo clips and sample mpegs, and i wanted to get them to play easier in fcp, so i used quicktime pro to Export as NTSC DV and, for comparison, QT Animation
    the files play fine in QT
    however, neither one will import into FCP. i get a file error message. (unkown file)
    AND the original mpeg or mov files import fine!
    i have done a search on these subjects and as such i have trashed the prefs (i think. ken stones description did not match what i found) and ran FCP rescue (i think. the site has dissapeared).
    is this to be expected? it seems others are having problems with QT and FCP, no?
    i guess i could import em, pop em on their own sequence, scale em up, render the sequence, then cut in the sequence where i need it.
    any other ideas? and any insight as to the qt pro thing?
    thanx in advance
    bee eph
    Jeremy Garchow replied 20 years, 8 months ago 2 Members · 2 Replies
