Activity Forums Adobe After Effects cannot get mask intersect mode to work for me
  • cannot get mask intersect mode to work for me
    Posted by Richard Sutcliffe on January 25, 2006 at 3:41 am
    I cannot fathom this out. I have broken this down to basics, I have a green solid layer as a BG with 4 white solid layers above it in the comp. I am creating text masks in PS and pasting them onto white solids in after effects. The intention is to apply a stroke and animate it to ‘draw’ the text. the animation I have got working fine, however, I want only the stroke to be visible and have therefore set the masks mode to intersect. As I understood it this would effectively hide the masks which do not overlap. However, intersect mode does nothing… What have I missed out? These little things drive me nuts.
    Ultimately there will be a motion BG behind the anim and cant get away with making the mask layers the same color as the BG.
    Any help gratefully accepted.
    RMS.
    Richard Sutcliffe replied 20 years, 7 months ago 2 Members · 2 Replies
  • John Dickinson
    January 25, 2006 at 5:03 am
    Set the Stroke effect’s “PAINT STYLE” parameter to “ON TRANSPARENT”.
    JD
    John Dickinson
    Motionworks
    http://www.motionworks.com.au
  • Richard Sutcliffe
    January 25, 2006 at 10:32 pm
    Thanks heaps for the that. I was following a tutorial which told me to have the setting to ON ORIGINAL IMAGE. Guess I should send them an email to query that advice.
    Thanks again.
    RMS
