Activity Forums VEGAS Pro cannot find the preview monitor display
  • cannot find the preview monitor display
    Posted by Andrew Rowe on September 15, 2007 at 9:55 am
    hi there
    i am a complete beginner and i have just started learning about making small films using sony vegas 5 and i am just finding my feet around the program so i apologise if i am asking a really simple question.
    i started doing some basics and watching the results in the preview monitor in the bottom right of the screen but then i must have clicked something wrong as the preview display disappeared and no amount of pressing alt4 will bring it back, even though it is ticked in the view menu i now cannot find it anywhere.
    can anyone let me know what i am doing wrong? please let me know if you need any more information
    many thanks in advance
    http://www.slatepipe.co.uk
    Andrew Rowe replied 18 years, 11 months ago 4 Members · 4 Replies
  • Matt Schwartz
    September 16, 2007 at 2:15 am
    It is minimized and hidden under the windows taskbar.
  • Greenmartian
    September 18, 2007 at 4:23 pm
    A shortcut to open the video preview window is ALT+4. That is, the ALT key and number 4 key down at the same time. Also, the video preview can be opened and closed in the drop down menu under “View.” It’s labelled “video preview.”
    Hope this helps.
  • Edward Troxel
    September 18, 2007 at 4:45 pm
    That will help if it’s not open at all. That won’t help if it’s already open but has been moved off the screen which is usually the case. It’s usually hidden somewhere off the screen that you can’t see.
    My usual suggestion is to change the screen resolution, find it, move it back to the main area, and then reset the screen resolution.
    In the newer versions of Vegas, you can also go to View – Window Layouts – Load Default Layout.
    Another alternative is to hold down CTRL-SHIFT and start Vegas. That will reset it back to “factory defaults”.
    Edward Troxel
    JETDV Scripts
  • Andrew Rowe
    September 18, 2007 at 10:42 pm
    thanks for all the replies, i got it sorted out. thanks
