Activity Forums Apple Final Cut Pro Cannot find media files after synchronizing double sound clips
  • Cannot find media files after synchronizing double sound clips
    Posted by Larry Watts on September 25, 2014 at 7:32 pm
    I used the synchronize audio and video feature for the first time, but cannot find the clips that were created on my system. I see them in the browser but not in the finder on any drive.
    I called a friend and he said apple now embeds these files into a master file or something.
    Is this true?
    He said he switched to primer because of this. (And so did several others)
    When I annually synched clips and rendered them I can find them just fine.
    What gives?
    What is the name of this master file and where is it?
    THX
    Robin S. kurz replied 12 years ago 3 Members · 2 Replies
  • Jeff Kirkland
    September 25, 2014 at 8:51 pm
    There are no clips to find outside of FCPX. The merged clips are virtual clips that don’t exist outside of FCPX’s database. If you’re looking to create new clips with the synced sound then use something like Pluraleyes.
    If your friend jumped to Premiere because of that issue he’s likely to be very disappointed. As far as I know it doesn’t handle synced clips any differently – or if it did I’d be mighty annoyed. Imagine if the only way you could sync audio on 200gb of clips was to create another 200gb of clips in the background. Ouch.
    As to whether clips are stored inside the FCPX library or not, that’s entirely up to you. Do a search for managed vs unmanaged/external media and FCPX. You’ll find plenty of free beginner training that explains how it works.
    Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
    http://www.southerncreative.com.au | G+: https://gplus.to/jeffkirkland | Twitter: @jeffkirkland
  • Robin S. kurz
    September 25, 2014 at 10:58 pm
    [Larry Watts] “I called a friend and he said apple now embeds these files into a master file […] He said he switched to primer because of this.”
    Wow. Your friend clearly had no clue what he was talking about. Probably best he switched, yes. 😀
    But to be honest, you appear to be missing even the most basic understanding of X also. Which is why I would recommend at least getting a minimum of training first or maybe reading the manual. A good place to start would be here: https://www.rippletraining.com/fcpx-features.html
    And Jeff already explained: synced clips (fortunately!) do not exist in the Finder, only its individual components (video file and audio file) do.
