Activity Forums Adobe Premiere Pro Cannot edit audio when track volume levels are applied
  • Cannot edit audio when track volume levels are applied
    Posted by Matt Chapman on March 12, 2017 at 10:34 pm
    Hey all-
    Having a real annoying issue with Premiere where I have a track which is the temp score. When i put audio on it everything plays fine, but when I add audio keyframes on the volume level on the TRACK, I can no longer edit the events. I have to create a new track, move it to there, and then re-edit, then copy down the track volume level manually. Very annoying.
    Can you not edit a track once you have applied the volume level (and added keyframes)?
    thanks
    Chapman
    Eric Santiago replied 8 years, 10 months ago 3 Members · 5 Replies
  • Matt Chapman
    March 13, 2017 at 5:48 pm
    UGH, this is really annoying. Happens all the time, is there a setting that can be changed?
  • Jerry Wise
    March 13, 2017 at 7:38 pm
    Make a “blade cut” while holding the “shift” key.
  • Jerry Wise
    March 13, 2017 at 7:55 pm
    i see what you mean now. i made audio clip keyframes and then made track keyframes and got the same result you did. as long as i am in the Track Keyframe mode then the audio channel can’t be highlighted unless i click off Track Keyframes and go back to Clip Keyframes.
  • Matt Chapman
    March 19, 2017 at 9:24 pm
    Does anyone know if this is an option that can be turned off?
    Irritating that if i include an audio track and even make a base mix keyframe on it to bring it down I then cannot edit anymore from there on the audio track.
  • Eric Santiago
    November 8, 2017 at 8:10 pm
    A colleague of mine applied keyframes under track keyframes.
    He then wants to move the group including the audio clip to a diff point in time.
    He can do this but the track keyframes don’t follow.
    Not sure how he got to this point I avoid using audio keyframing in most NLE.
    I use ProTools for things like that.
