cannot delete this track
Posted by Ross Sutherland on August 25, 2011 at 7:43 amJohn Rofrano replied 15 years ago 2 Members · 3 Replies -
John Rofrano
August 25, 2011 at 6:35 pm[Ross Sutherland] “cannot delete this track”
Press “Ctrl+Shift+B to hide the Master Video Bus Track.
[Ross Sutherland] “how can you set the timeline to always load with the settings you like eg in 1 second allotment?”
You can set the timeline default to be “Seconds” but you can’t specify the resolution that is shown. The timeline always defaults to showing the entire timeline when it first loads. Then you have to zoom in.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Ross Sutherland
August 26, 2011 at 9:11 amthanks John , ok now
John Rofrano
August 26, 2011 at 3:22 pm[Ross Sutherland] “how can you set the timeline to always load with the settings you like eg in 1 second allotment?”
Go to File | Properties (Alt+Enter) and on the Ruler tab set the Ruler Time Format to Seconds. Then at the bottom of that window, check [x] Start all new projects with these settings and press OK. All of your new projects will start with the timeline ruler set to seconds.
~jr
