Activity › Forums › Adobe Premiere Pro › cannot capture
cannot capture
Posted by Lefteris Sifidis on October 17, 2009 at 11:56 ama message appears ‘device not recognized’. might be a cable problem?
Brian Louis replied 16 years, 11 months ago 2 Members · 3 Replies -
Brian Louis
October 18, 2009 at 12:56 pmMaybe you should tell people what device(brand, model) you are trying to capture from, and what kind of cable(firewire, usb, composite, component, etc) you are trying to use
Lefteris Sifidis
October 18, 2009 at 1:40 pmit’s a sony minidv via firewire. it workrked perfectly till now
Brian Louis
October 18, 2009 at 7:07 pmIt could be a cable, It could be the port on the cam, they have been known to blow if hot swapped, same with the port on the computer, I would find another cable to test with and if that doesn’t work, try another computer, and or try to connect two camcorders together via firewire and see if they will xfer data between them, process of eliminajtion, when connecting to computers don’t do it when both are on, connect with both off and then bring up.
