Activity › Forums › Sony Cameras › Cannot capture from Sony EX1 -> MX02/Max(SDI In) @ 1080p@
  • Cannot capture from Sony EX1 -> MX02/Max(SDI In) @ 1080p@
    Posted by Shawn Sutherland on December 8, 2010 at 12:07 am
    Hi all:
    …to the point:
    Our regular test setup was that we recorded a small 3-minute video at 1080p@24fps (actually it is 23.98fps) compreesed onto the built-in SxS-memort cards (.mxf/mp4) of the Sony EX1 HD-camera.
    Then after, we would play it back “de-compressed” via the SDI-Out (BNC) of the Sony EX1 —> thru the MX02/Max(SDi-In).
    Note: We prevously used a Blackmagic declink/SDI card to capture from Sony’s EX1 XDCAM -using the “uncompressed”/”raw” (HD/SDI Out) BNC connector.
    The SDI-out of the Sony EX1 was set to HQ/HD 1080p@24 (for film quality uncompressed 10-bit)
    However, the decklink would only capture at 1080i@59.9 Hz uncompressed AVI (v210) format ? It wasn’t that bad at all, but we wanted MORE! Wink
    So, we got this Matrox MX02/MAX becuase it will capture uncompressed SDI-out 10-bit at 1080p x 24 fps (NTSC) ?
    But the only way we can see the output of the Sony EX1 via the SDI-In of the MX02 is by setting the “Project Format” to 720p@59,94 fps.
    The quality via Adobe CS5 is actually not that bad, but the point is,
    – So What am I doing wrong here ?, and/or
    – Has anyone else experienced this problem using a Sony EX1 (SDI-Out to MX02 SDI-In) ?
    Regards, and thanks ahead for any feedback/help you can offer.
    And well, excuse my “n00b”ness here.
    Smile
    Rick.
    Craig Seeman replied 15 years, 10 months ago 2 Members · 1 Reply
  • Craig Seeman
    December 8, 2010 at 1:34 am
    I use EX1 and MXO2-LE for live streaming but I’ve no problem using 1080 and have used 720p24 and p30 as well. I do have to set the MXO2 to 8bit rather than 10 bit though in Wirecast.
