Activity › Forums › DaVinci Resolve › Candle light test with Beta3 and 3x GTX 570
Posted by Helge Tjelta on August 22, 2012 at 7:36 amall at 24 fps, except N1 at 10 fps…
/HelgeHelge
Eric Santiago replied 14 years ago 6 Members · 8 Replies -
Sascha Haber
August 22, 2012 at 8:13 amTime to update the “Standard candle” then..
I´m on it…I’ll find a way to slow you down 😉A slice of color…
DaVinci 8.2.1 OSX 10.7.2
MacPro 5.1 2×2,4 24GB
RAID0 8TB
GTX 470 / Quadro 4000
Extreme 3D+ICA Instructor
https://www.icolorist.com/Sascha.html -
Kevin Cannon
August 22, 2012 at 4:37 pmI started just taking Sascha’s old one and upping the resolution to 4096×2160. Seems to work as expected (basically is 4 times harder for the cards). I put some results in this thread, but didn’t have a 580×3 set up to test, I’d be curious what you get.
Cheers,
KC
Jonathon Lee
August 22, 2012 at 5:06 pmHey Helge,
What is the rest of your config? Are they “stock” 570’s? Curious about OS and pci chassis you are using.
thank you,
Jonathon
Helge Tjelta
August 23, 2012 at 7:36 pmAll stock, regual 570’s with 2.5 GB.
OS is 10.7.4, 48 GB RAM, MacPro Dual 6core
ATI 5770 for GUIRedRocket card and 3x 570 in cubix 4 desktop expander
/Helge
Helge
Esteban Aguilera
August 30, 2012 at 5:28 pmWhat i dont understand from this test,
1 what is the file you are using ?
2 you can manipulate the settings to give better playback, I suppose they are stock.
But I dont have stock settings, I just use 2 settings for playback/grading and for rendering.using and H264 shot from the tutorial that came whit R9b3 I have 9,5fps if I use my renderings settings and 24 with the grading settings.
I can go up to 20nodes at 22fps using my grading setup.
My hard:
hackintosh i7 2600k
Gt120 / GTX 460Di Davinci Resolve Colorist
Eric Santiago
September 8, 2012 at 7:14 pmis there an update to this test file?
I cant seem to find step by step instructions.
I downloaded the tar file but no instructions as to which image to use for testing.
better yet, I have a few sequential DNG files from a Black Magic Cinema, its 2.5K res and would like to use that as a test option.
