Canceling any change between two keyframes
Hello. This is probably a “beginner’s question” –
I have two keyframes in the ‘Position’ property (of a 3D layer). They both have exactly the same values (I want that layer to be frozen for the duration of those two keyframes) – however, there is change – it seems the values goes up to until about the middle point in the timeline between the two keyframes and starts going down again until it reaches the values from the first keyframe. I want it to stay still. Is it moving because there are “leftovers” there from when I moved it before, or something like that? There are no other keyframes in any other layer in the duration of those two keyframes…
How can I tell AE to simply don’t do anything between those 2 keyframes?Thanks.
