Activity Forums Maxon Cinema 4D Can you use xpresso to make effectors effect any property of a clone?
  • Can you use xpresso to make effectors effect any property of a clone?
    Posted by Arne Münch on July 2, 2011 at 6:47 pm
    If you have for example a bend deformer bending a cube and make a 20 * 20 field of these cubes using a cloner object, can you now use a random effector to change the strength or angel of the bend deformer individually for each clone?
    I searched the web for this thing and in some places I read that xpresso can only be used to get data out of clones, but not to set them. But I would like to be sure about this.
    thanks for any help
    Arne Münch replied 15 years, 2 months ago 2 Members · 2 Replies
  • Brian Jones
    July 3, 2011 at 4:53 am
    I think the clones are instances and while you can read the data from the clones you can’t read or affect the bend which is a child of the clone. But you can animate the bend then fool with the time of the animation with effectors.
    2499_randombentclones.c4d.zip
  • Arne Münch
    July 3, 2011 at 1:07 pm
    yes, thanks, this is a good way to solve this.
