Activity › Forums › Adobe Illustrator › Can you specify an angle to rotate/skew, but around a different reference point?
  • Can you specify an angle to rotate/skew, but around a different reference point?
    Posted by Sam Yost on October 1, 2016 at 9:35 pm
    When you use the skew or rotate menus, the reference point is always in the center. Is there a way to specify a different reference point and then say “rotate” by X degrees? I do this action a lot and it’s really annoying to always drag-rotate around the point until I’ve got it juuuuuuust close enough with the angle counter on the cursor.
    Vincent Rosati replied 9 years, 12 months ago 2 Members · 1 Reply
