Activity › Forums › Maxon Cinema 4D › Can you scale by a higher factor?
  • Can you scale by a higher factor?
    Posted by Dustin Bowser on July 3, 2010 at 2:46 am
    In C4D, is it possible to hold a modifier key when scaling in order to scale by a higher factor? Similar to After Effects how you can hold shift and it will scale by a factor of 10 rather than one.
    Does that make sense?
    Adam Trachtenberg replied 16 years, 3 months ago 2 Members · 2 Replies
  • Dustin Bowser
    July 3, 2010 at 2:54 am
    Also, along those same lines, is it possible to control the factor by which you orbit in the scene? I’m finding that it’s taking several strokes to orbit around a simple object.
  • Adam Trachtenberg
    July 3, 2010 at 6:19 pm
    There’s no modifier to increase scaling speed, but you can scale faster by doing the operation multiple times instead of doing one long drag.
    You can change the editor move/rotate/scale speed in preferences>viewport.
