Activity Forums Adobe Premiere Pro Can you save titles with transitions as a template?
  • Can you save titles with transitions as a template?
    Posted by Cenk Erdil on January 11, 2009 at 12:00 am
    Is it possible to save a still title in PPro CS3 with certain transitions?
    I use crossfade effect for name captions. Although I have a template for the title, I need to apply the effect manually every time to the beginning and end of the title…
    It is time consuming if you are using the template over and over again…
    So if I can save the title template with the transition already applied, this would make life easier…
    Thanks for any thoughts…
    Cenk Erdil replied 17 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
