Activity › Forums › Adobe After Effects › Can you read the metadata used by the “Edit Original” command?
  • Can you read the metadata used by the “Edit Original” command?
    Posted by Gage Ullman on September 12, 2018 at 9:09 pm
    I’ve encountered a problem where I’m pressing command+e to open the project associated with a render out of after effects, and it just keeps opening in quicktime. I assume that means that the drive the original project was on is not connected, and I have no idea where to look for it. If I could read the metadata that After Effects uses to open the original project that a movie was rendered from, though, I might be able to at least get a file path to give me a clue where to start looking, or at least that’s my thinking. Anyone know if theres a way to do that?
    Walter Soyka replied 8 years ago 2 Members · 2 Replies
  • Gage Ullman
    September 13, 2018 at 3:21 am
    Well, as stated, the drive on which the project file has likely been disconnected and vaulted somewhere. So searching in my OS would be useless. The intention here is to see if I can use the metadata from the file I have to find the name of a drive. If I could read the metadata (i.e., the file path used by After Effects when it opens a project using the command-e shortcut) then I could find out what drive it’s on and see who in my office vaulted it and when. Then I could locate it.
  • Walter Soyka
    September 13, 2018 at 9:18 am
    Gage, try opening the movie in a text editor and searching for “aeProjectLink” (without the quotes). The file path for the original AEP should be a few lines below that if “Include project link” was enabled at render time.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
