Activity Forums Adobe After Effects can you print to tape (digital cut) from AE
  • can you print to tape (digital cut) from AE
    Posted by Stephen Hockman on November 16, 2005 at 5:17 pm
    is it possible to put your compostion to a tape in AE. FCP does it under Print to tape, and Avid under Digital cut. What about AE?
    Scottieb replied 20 years, 9 months ago 3 Members · 2 Replies
  • Mstleger
    November 16, 2005 at 6:24 pm
    No. Avid and FC are editing software, which is capable of making render files that can be played back in the comp. AE does not do this, AE renders to RAM when playing the video in the comp. Previews in AE are very limited because of this.
    Just render from AE, import to the edit suite of your choice, then print to tape there.
  • Scottieb
    November 17, 2005 at 4:12 am
    If you can RAM preview to FW, couldn’t you just hit record on your deck while the preview is playing? You’d need some decent timing, but you could do it. There is no “print to video” feature, per se, but if you can get the signal out via firewire, then you can record it.
    SB
