Activity Forums Adobe After Effects Can you keep only black in footage and make everything else transparent?
  • Can you keep only black in footage and make everything else transparent?
    Posted by Joe Marston on January 29, 2015 at 3:18 pm
    So i have this effect called unknoll, and it removes black from any footage. (obvious reasons why its useful) but i have footage that is a transition into black and i want to keep the black and remove the background footage. sooo i need everything to be transparent except black. i tried a few things, and got nowhere. does anyone know how to do this? is it possible?
    John Cuevas replied 11 years, 8 months ago 2 Members · 1 Reply
  • John Cuevas
    January 29, 2015 at 5:16 pm
    Use a luma key, set it to key out brighter and set the threshold low, 16.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
