Activity Forums Canon Cameras can you get a uncompressed output via HDMI from the Canon 5D Mark II while NOT recording?
  • can you get a uncompressed output via HDMI from the Canon 5D Mark II while NOT recording?
    Posted by Chris Baldwin on September 29, 2010 at 6:45 am
    I came across this today.
    https://www.atomos.com/
    Is there anyway to output an uncompressed 1920×1080 progressive signal from the HDMI port on the canon 5d mark II? I was under the impression that it only output 1080i via the HDMI port while not recording and then switched to SD during recording.
    Richard Van den boogaard replied 15 years, 12 months ago 2 Members · 1 Reply
  • Richard Van den boogaard
    September 29, 2010 at 7:51 am
    Interesting question, although I am not sure if this helps…
    I was just looking at some videos yesterday from Teradek, who have come up with a system that allows for ad-hoc wi-fi networks. Read the review on PhilipBloom.net. Using a separate recorder would allow you to bypass the issue of resolution-dropping.
    Richard van den Boogaard
    cameraman / editor / video marketing consultant
    Branded Channels
    W: http://www.brandedchannels.com
