Activity › Forums › Apple Final Cut Pro Legacy › Can you edit HD CAM on FCP 6?
  • Can you edit HD CAM on FCP 6?
    Posted by Rogelio Cordovez on June 20, 2007 at 11:56 pm
    Can someone please tell me if there is a way of editing HD Cam on FCP 6?
    Can you do it on a G5 Quad (not intel)?
    Would IO HD from AJA do it?
    Thank you any info is appreciated
    Tapes come from a Sony HDWF 500 VTR
    editguy
    Rogelio Cordovez replied 19 years, 3 months ago 6 Members · 7 Replies
  • 7 Replies
  • Gary Adcock
    June 21, 2007 at 12:02 am
    [editguy] “Can someone please tell me if there is a way of editing HD Cam on FCP 6?”
    you could do that in FCP 3
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
  • Rogelio Cordovez
    June 21, 2007 at 12:21 am
    Thank you for the quick response. I knew you could edit HD on FCP, maybe I should re-phrase my question.
    What hardware do you recommend? I would be digitizing the material from a Sony HDWF 500 VTR. Would the AJA I/O HD be the way to go, maybe the Kona 3 card or how about the Blackmagic Eclipse?
    What’s your suggestion?
    editguy
  • Walter Biscardi
    June 21, 2007 at 12:35 am
    Kona 3 is the desktop standard.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Michael Gissing
    June 21, 2007 at 12:37 am
    I have the Decklink HD Pro card and capture/edit to tape HD SDI from any of the HDCam decks 500, 2000, 1800 without problem. There are many Kona and Decklink cards. All you need for HDCam is a card with HD SDI in and RS422 control, so I would be looking at the other features of the various cards to determine the best price & features. I don’t need analogue in for example but need component monitoring out.
    Most important is a fast and big external RAID. I am using a 4TB sata RAID with dual fibre. This works fine for uncompressed 50i & 60i.
  • Tom Matthies
    June 21, 2007 at 2:26 pm
    I use a Quad 2.5G5, Kona 3 and a pair of Huge raids to edit HDCam at 10 bit uncompressed, although I usually convert to DVCProHD. I bring the footage in HDSDI from the deck thru the Kona 3. It’s pretty straightforward and I’ve had no problems at all. It works.
    Tom
  • Joe Huggins
    June 21, 2007 at 8:07 pm
    I noticed you use a sata RAID and dual fibre. What brand? We have a dual fibre Medea SAN on a MacPro and G5, but I’d like to add a 2TB local sata to the MacPro to handle 444 10bit. Is there a card conflict issue? Can you recommend a good price/performance drive set?
    Thanks, Film Joe
  • Rogelio Cordovez
    June 22, 2007 at 7:02 pm
    Great feedback, thanks to everyone, I will be doing some research, and go ahead with the HD transition.
    Thanks again for all the replies.
