Activity › Forums › Adobe After Effects Expressions › Can you delay a layers start with a slider for use in a MoGRTs?
  • Can you delay a layers start with a slider for use in a MoGRTs?
    Posted by Henry Gaunt on June 23, 2021 at 1:50 pm
    Hello,
    I have a sequence with 7 precomps (all the animation happens within each preocomp), can you link each of these precomps to a slider so that the editor can delay the start of each precomp to time it with a voice over in premiere?
    My comp is 25fps, so if they move the slider to ’50’ it would push back the precomp 20 seconds, or 450 for 3 minutes etc..
    Thank you
    Henry Gaunt replied 5 years, 3 months ago 2 Members · 4 Replies
  • Dan Ebberts
    June 23, 2021 at 2:53 pm
    Maybe turn on time remapping for the precomps and add a time remap expression like this:
    s = thisComp.layer("Control").effect("Delay 1")("Slider");
    delay = framesToTime(s);
    Math.max(0,valueAtTime(time-delay));
  • Henry Gaunt
    June 23, 2021 at 11:22 pm
    I do like the quiet confidence in your posts. I know when I’ve found a post with your name it will work!
    Thank you Dan, spot on.
    Is there a line I can add to turn the slider into seconds, so on the slider; 1 = second, 60 represents a minute etc..
  • Dan Ebberts
    June 24, 2021 at 4:05 am
    This should work:
    delay = thisComp.layer("Control").effect("Delay 1")("Slider");
  • Henry Gaunt
    June 24, 2021 at 8:15 am
    <div>
    </div>
    Thank you Dan!
