Can you copy effects across multiple comps/still images?
Hey,
I’m creating a video from a series of still images, the idea will be to travel through them over time in w/the 3d cam. As the camera passes each image, I want them to fade away, and I’ve been doing a shatter to do this. I’ve actually been using this tutorial – https://ae.tutsplus.com/tutorials/vfx/design-a-breathtaking-body-shatter-effect/
I’ve got it working for one of the images, so hurrah for that. However, my question is = is there a way to apply the shattering to each of the images, aka so they each shatter. If I can ‘copy/paste’ this effect then it’ll save me having to manually do it for each image, which’ll be a big time saver, esp as I’m not the best at this.
If there isn’t a way I’ll have to do it manually which’ll take a lot of repetitive time!
In the above tutorial there’s a lot of comping/precomping so there’s essentially multiple layers of stuff going on you see, so it’s not a case of just copying the one effect, there’s the tree of stuff going on.
