Activity › Forums › Apple Final Cut Pro Legacy › Can you configure LaCie 3TB d2 USB 3.0 Thunderbolt drive to RAID 1?
  • Can you configure LaCie 3TB d2 USB 3.0 Thunderbolt drive to RAID 1?
    Posted by Paul Donahue on April 25, 2013 at 8:23 pm
    For the life of me I haven’t been able to find on the Internet whether you can configure the LaCie 3TB d2 USB 3.0 Thunderbolt drive to RAID 1. Is this possible to do? And, if it is not, are there other external Thunderbolt/USB 3.0 drives that are good for video editing and can be configured as RAID 1 drives?
    Thanks in advance,
    Paul
    Paul Donahue
    Media Eye
    http://www.mediaeyemedia.com
    Carolina Rodriguez replied 12 years, 8 months ago 5 Members · 7 Replies
  • 7 Replies
  • Shane Ross
    April 25, 2013 at 8:44 pm
    You can’t. There’s only one drive in the case. RAID 1 would require at least two drives.
    Shane
    Little Frog Post
  • Paul Donahue
    April 25, 2013 at 9:04 pm
    Too bad. Do you happen to know of a drive that you can configure for RAID 1 that has both USB 3.0 and Thunderbolt, and is good for video editing?
    Paul Donahue
    Media Eye
  • Shane Ross
    April 25, 2013 at 9:37 pm
    That has BOTH? You’ll be hard pressed to find a RAID drive that offers both. In fact, the only drive I found in my cursory 10 min google search that had Thunderbolt AND USB 3 was the hard drive you mentioned.
    Shane
    Little Frog Post
  • Steve Eisen
    April 26, 2013 at 4:36 am
    Just stick with a Thunderbolt RAID. Lacie, G-Tech or Drobo Mini would work great.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Creative Pro Users Group
  • Taylor Long
    April 26, 2013 at 10:14 pm
    You would need two physical disks to build a RAID 1 array.
    About RAID Modes
    RAID 0 (FAST): RAID 0, is the fastest RAID mode. In a RAID 0 array, the available capacities of each drive are added together so that one logical volume mounts on the computer. It offers the best performance but no protection in the case that a drive fails.
    Caution: In a RAID 0 array, if one physical drive in the array fails, the data of all drives becomes inaccessible because parts of the data have been written to all drives.
    RAID 1 (SAFE): RAID 1 provides data safety since all data is written to each drive at the same time. In the event of a single drive failure, data remains available on the other drive. Due to the time it takes to write the data twice, performance is slightly reduced.
    RAID 1 is a good choice when safety is more important than speed. However RAID 1 also reduces the available drive space by 50% due to the need to write each bit of data on each hard drive.
    Here is a link to some of our RAID products.
    https://www.lacie.com/products/range.htm?id=10061 ~TE, LaCie
  • Paul Donahue
    April 27, 2013 at 2:56 pm
    Thanks for all the responses.
    Paul
    Paul Donahue
    Media Eye
  • Carolina Rodriguez
    January 9, 2014 at 10:12 pm
    Hi everyone,
    Can i do this: From de codex – Mac Pro SAS – Thunder stream sc 3808 – Lacie d2 quadra thunderbolt (No raid)?
    Thank u
    Carolina Rodriguez
