Activity › Forums › DVD Authoring › Can you combine upper and lower field sd video on a dvd?
  • Can you combine upper and lower field sd video on a dvd?
    Posted by Dennis Stimac on April 18, 2013 at 8:03 pm
    I have some hd down-converted to sd upper field first and some sd lower field footage i’d like to combine together on a dvd. The upper field is for the main title and the lower field video is for the menu background video only.
    I know I could de-interlace the menu video and re-render as upper field, but id rather stick with the master copy settings as-is, if I could.
    Could this cause potential playback or viewing issues on some dvd players or does it not matter?
    I plan on distributing copies of this video and wouldn’t want any incompatibility.
    Thanks in advance.
    Eric Pautsch replied 13 years, 5 months ago 2 Members · 1 Reply
  • Eric Pautsch
    April 18, 2013 at 8:50 pm
    You’re fine as long as its not in the same title (track)
