Activity Forums Adobe Premiere Pro can you capture ProRes on a mac with a blackmagic or aja card?
  • can you capture ProRes on a mac with a blackmagic or aja card?
    Posted by Chris Borjis on January 18, 2012 at 6:58 pm
    Just searched the threads and don’t seem to see a definitive answer.
    I want the ability to capture ProRes in premiere pro cs 5.5
    with my aja or black magic capture card.
    all I see is uncompressed 8 or 10-bit and a few other options but
    prores not listed.
    I do have final cut pro 7 installed on these machines so
    the prores encoder/decoder is installed.
    and one last thing, anyone know why my export, tape option
    is grayed out?
    need to run some edit to digibeta / beta tests.
    thanks!
    Shane Ross replied 14 years, 8 months ago 4 Members · 12 Replies
  • 12 Replies
  • Chris Borjis
    January 18, 2012 at 11:06 pm
    someone on a post here said you could capture prores, but unless I’m missing something, it cannot be done within premiere.
    both my bmd and aja cards are only offering uncompressed options.
    hopefully adobe will address this in cs 6.
    I should not have to use another separate app to capture tapes.
    I know tapeless is the now and future, but some of us still have clients that need it.
  • Shane Ross
    January 19, 2012 at 2:32 am
    Premiere can’t do it. It doesn’t have the license for ProRes. You have to use the capture tool provided by AJA or BMD, and FCP will have to be installed (to have access to the codec).
    Shane
    Little Frog Post
  • Chris Borjis
    January 19, 2012 at 5:31 pm
    interesting.
    I guess aja and bmd can’t just slip the option in their since they provide the interface.
  • Shane Ross
    January 19, 2012 at 5:38 pm
    The “option” would be to license the ProRes codec from Apple. Dunno how expensive it is. But not something they are doing at this time.
    THIS is why Adobe needs it’s own codec. Or…hmmm…DNxHD encoding is free from Avid. But I don’t think you can capture to it with AJA or BMD and PPro…in fact, I’m sure you can’t.
    Shane
    Little Frog Post
  • Jim Wiseman
    January 20, 2012 at 4:37 am
    You can get all of the the ProRes Codecs with Motion 5 from the Mac App store. Motion is $49.95. Requires 10.6.8 or above.
    Jim Wiseman
    Sony PMW-EX1,Pana AJ-D810 DVCPro, DVX-100, Nikon D7000, Final Cut Studio 2 and 3, Media 100 Suite 2.1, Premiere Pro 5.0 and 5.5, AJA ioHD, AJA Kona LHi, Avid MC, Hexacore MacPro 3.33 Ghz 24Gb RAM 120GB SSD, Macbook Pro 17″ 2011 2.2 Ghz Quadcore i7 8Gb SSD, G5 Quadcore PCIe
  • Chris Borjis
    January 20, 2012 at 6:57 pm
    Thanks Jim, but I have final cut studio 3 installed.
    I have the codecs.
    they just won’t come up as codec options under the black magic or aja capture utilities in premiere.
  • Shane Ross
    January 20, 2012 at 7:04 pm
    [Chris Borjis] “they just won’t come up as codec options under the black magic or aja capture utilities in premiere.”
    You cannot capture as ProRes in Premiere. YOu will have to use the AJA or BMD capture tools.
    Shane
    Little Frog Post
  • Chris Borjis
    January 20, 2012 at 11:56 pm
    I know, I was explaining to Jim the situation. 🙂
  • Jim Wiseman
    January 21, 2012 at 12:00 am
    I use the AJA utility.
    Jim Wiseman
  • Thomas Smet
    January 27, 2012 at 4:07 pm
    I understand CS5.5 cannot capture to ProRes but what about playback of ProRes files in a sequences designed for one of those cards?
    I am ok with using an external app to capture but being able to actually edit with the card would be very important.
