Activity › Forums › Apple Final Cut Pro Legacy › Can You Automate FCP?
Sean Oneil
March 5, 2008 at 10:29 pmIf you want a custom XML app, you need the jedi master, Andreas Kiel.
https://www.spherico.com/filmtools/
Sean
Josh Mellicker
March 6, 2008 at 1:52 amThis movie shows how to do this:
https://www.dvcreators.net/how-do-i-add-transitions-to-multiple-clips-all-at-once-in-final-cut/
Nick Meyers
March 9, 2008 at 1:39 pmhere’s how you can do this in FCP:
drop all the clips into an FCP timeline;
apply Digital Heaven’s DH_Fade filter.
https://www.digital-heaven.co.uk/fcplugins/dh_fade.php
with this you can program a specific fade in AND fade out on a clip.drag all teh clip to a new bin.
batch export as QTMovie: self contained, same settings.if all the clips are the same duration you could keyframe opacity in & out on the first one,
then copy and paste attributes: opacity.
if the clip aren’t the same duration the fade lengths will changehope that helps,
nick
