Activity › Forums › Maxon Cinema 4D › Can you apply effectors to animated parameters?
  • Can you apply effectors to animated parameters?
    Posted by Jeff Corbett on October 25, 2012 at 3:50 am
    I have created some liquid using 2 planes, extrude nurb, and a displacement. I am trying to get random heights and size in the liquid.
    i even added a hyper nurb to smooth the plane and of set the planes to see if i could get sudo organic differences in the liquid.
    I have made very nice material but the displacement is too uniform, so i tried to use a random effector on the displacement.
    How do i get the random effector to effect the displacement?
    “”In order to do something well, you have to actually do something.””
    > Knowledge + Action = Wisdom <
    Jeff Corbett replied 13 years, 11 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    October 25, 2012 at 4:46 am
    Instead of trying to use Mograph I would just work on the displacement material. Try using the layer shader with different noises using different scales, using the overlay transfer mode. You can also put a noise shader in an alpha mask channel.
  • Jeff Corbett
    October 25, 2012 at 10:00 pm
    thanks.
    I was trying to get the liquid’s wave density and size to be different in some areas. Someone mentioned using expresso but i am so new to that its a bit of a hefty order.
    I think the problem is that c4d is using a plane to displace and i dont know how to specify the strength of the displacement. sorta like a travel matte would do when animated in ae.
    I also added some ambient occlusion and got better contrast and a deeper look.
    I have only been at c4d for 1year and mostly for text.
