Activity › Forums › Apple Final Cut Pro › Can you adjust the line spacing on the typewriter effect?
  • Can you adjust the line spacing on the typewriter effect?
    Posted by David Taylor on July 9, 2021 at 9:06 pm
    Is this possible? Nothing happens when I adjust line spacing using the typewriter effect. I assume this is the same as “leading.”
    David Taylor replied 4 years, 6 months ago 3 Members · 3 Replies
  • Mark Smith
    July 11, 2021 at 11:41 pm
    The answer to your question might be the “custom” title choice which has controls for direction, speed, sequence of write on and write off.
  • David Battistella
    July 27, 2021 at 7:37 am
    You can try opening the effect in motion and creating a copy. Adding the parameters you would like to control and publish the “new title” your custom version back to FCP.
  • David Taylor
    March 10, 2022 at 7:40 pm
    Actually, the answer is to select the text in the viewer, then the adjust slider will work. You just can’t adjust it without selecting the text. Which is actually better, since you can select individual lines of text and adjust it independently of the rest.
