Activity › Forums › Apple Motion › Can you add motion blur selectively or is it always global?
  • Can you add motion blur selectively or is it always global?
    Posted by Phil Williams on December 14, 2009 at 12:41 am
    Does Motion allow to you to switch on motion blur just for specific layers, or does it have to be global?
    Zak Peric replied 16 years, 9 months ago 3 Members · 4 Replies
  • Mark Spencer
    December 14, 2009 at 1:40 am
    It’s global.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Zak Peric
    December 14, 2009 at 8:26 am
    It is a global thing. You could apply motion blur to objects in your projects to preview what could be motion blur. You can also solo the layer and do a render preview with motion blur on. to solo the layer first select the layer or a group then go to object and press solo. Then do a ram preview.
  • Phil Williams
    December 14, 2009 at 8:26 pm
    Thanks for the responses guys, although it’s not what I wanted to hear 🙁
    I’m just about to start a project where I’d like foreground graphics to be motion-blurred while background graphics stay crisp, so I guess the only way to achieve that would be to render out the foreground graphics separately with motion blur and an alpha channel, and then composite them onto the backgrounds?
  • Zak Peric
    December 14, 2009 at 8:34 pm
    See, you knew the answer all along.This is a good attitude to have, find a fix to a problem, implement it and move on.
