Activity Forums VEGAS Pro Can you add a plugin chain to multiple clips?
  • Can you add a plugin chain to multiple clips?
    Posted by Seranya Myor on April 30, 2012 at 8:54 pm
    I though it would work by selecting the events and adding the plugin chain but it didn’t… Is there a way I don’t know of or is this not available in SV?
    Seranya Myor replied 14 years, 4 months ago 2 Members · 2 Replies
  • John Rofrano
    April 30, 2012 at 10:04 pm
    [Seranya Myor] “I though it would work by selecting the events and adding the plugin chain but it didn’t… Is there a way I don’t know of or is this not available in SV?”
    No, you would have to add the chain to each event individually. You could also Copy & Paste Event Attributes i.e., add it to the first event, select copy, select all the other events and apply Paste Event Attributes and all of the events will get the same plug-in chain as the copied event. Be carful with this as it will also copy any pan/cropping that you may have done.
    You can also add the plug-in chain to a new track and move those events onto that track.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Seranya Myor
    April 30, 2012 at 10:35 pm
    Yes I know, that’s why I never used paste even attributes because it copied everything else as well. I was hoping there was actually a way I wasn’t aware of. But thank you for the track fx idea! I really didn’t think of that! It could be helpful when I don’t already have too many tracks to get lost into…
