Activity › Forums › Audio › Can you adapt a radio mic to work hard wired?
  • Can you adapt a radio mic to work hard wired?
    Posted by Eric Susch on June 29, 2006 at 12:26 am
    Anyone know if it’s possible to purchase (or make) an adapter so that you can use a Countryman B6 lav that has a Lectrosonics connector on the end and hard wire it? Would a short 5-pin to XLR adapter cable work and allow you to phantom power the mic directly into a mixer or recorder? Anyone tried something like this?
    Eric Susch replied 20 years, 3 months ago 4 Members · 4 Replies
  • Will Salley
    June 29, 2006 at 2:56 am
    I saw something like this on the Lectro site.
    https://www.lectrosonics.com/manuals/mca5xtd.pdf
    I have a cable that makes this connection, however, I think the bias voltage of the B6 is incorrect for standard 48v phantom. I haven’t used it on the B6 – I don’t want to damage the mic.
    I think it depends on the model of Lectro transmitter for which the mic is wired. Here’s the info from Countryman’s site for the UM400.
    Lectrosonics UM400
    Switchcraft TA5F
    Pin 1 = Shield
    1.5k ohm Pin 2 to 3
    3.3k pin 3 to white
  • Tom Maloney
    June 29, 2006 at 11:30 am
    Before I would try anything, I would contact a good audio company such as Trew. i know you can do this with the correct connection
    good luck
    Tom
  • Ty Ford
    June 29, 2006 at 12:06 pm
    Contact Countryman directly and ask about getting a “link.” COuntryman makes links for all of their mics. It’s a TAF to xlr/power supply that does just what you want. I have one.
    Ty Ford
    Ty Ford’s “Audio Bootcamp Field Guide” was written for video people who want better audio. Find out more at https://www.tyford.com
  • Eric Susch
    June 29, 2006 at 4:01 pm
    Thanks everyone!
    Looks like there’s more than one way to do this. …And I’m glad I don’t have to break out the soldering iron 😉
