Can we resize video in PLatinum HD 10.0?
Posted by Jim Ho on January 30, 2011 at 4:21 amI’m using the trial version of 10.0.
I have not been able to resize videos from the Panasonic GH1 from 1080i 30 to 720p 30. Have not trancoded.
Need help. Is it possible? How?
Thanks very much for your help.
Jim
Mike Kujbida replied 15 years, 7 months ago 2 Members · 4 Replies -
Mike Kujbida
January 30, 2011 at 6:37 pmA lot of things are possible in Vegas.
Why do you want to do this?
What format do you want to render to? -
Jim Ho
January 31, 2011 at 2:53 amHi Mike,
Thanks for answering. I am trying to convert Panasonic GH1 AVCHD to WMV or MP4.
AS you may know, the 1080p 24 video is coded as a MPEG2 (transport) 30fps interlaced. With Vegas Platinum, I can convert it as 1080i 30 to a MP4 or WMV (Quality VRB).
Currently, I am trying to mix 1080 and 720 files in a project. It works fine after I have rendered the m2ts files into WMV. But, it balks when I use 1080 files that have not been rendered.
Just wondered if it is possible (to cut the work flow) to work with the original m2ts files.
Also, I was wondering why rendered AVI videos won’t playback in WMP (Vista OS). I assumed that AVI should since it is a Windows container?
Jim Ho
January 31, 2011 at 12:07 pmSolved the problem.
Downloaded Microsoft’s Mats_Run.Codec to identify and repair the problem. But, it won’t install.
So, I restarted the computer and it appears to have repaired the problem. Everything back to normal.
Mike Kujbida
January 31, 2011 at 2:26 pmI’ve never heard of Mats_Run.Codec but I’m glad to hear that things are working for you again.
