Activity › Forums › Apple Final Cut Pro Legacy › CAn we import flash (fla & swf) files into FCP?
  • David Roth weiss
    May 29, 2007 at 2:14 pm
    Paul,
    You will have to transcode to quicktime before using either Flash format in FCP. Not sure what app does that…
    BTW, I just tried importing a SWF into FCP 6 and it doesn’t work in ver. 6 either.
    David
    David Roth Weiss
    Director/Editor/Post-production Supervisor
    David Weiss Productions, Inc.
    Los Angeles
  • Ben Oliver
    May 29, 2007 at 2:26 pm
    sometimes…the best way is to get a nice monitor and just shoot it off the screen!
  • Stuart Simpson
    May 29, 2007 at 2:50 pm
    If your files end in .flv you might have luck installing the Perian Quicktime plugin:
    http://www.perian.org
    -Simmie
    2 G5 – Kona LH
    3 G4s – Cinewave
    1 xbox360, 1 PSP, 1 PS2 & a Gamecube
    https://www.speak.co.uk
  • Brian Pitt
    May 29, 2007 at 3:45 pm
    I had to do this a couple of weeks ago. I had to download a program called SWF2Video Converter. you can convert the SWF to an AVI file and you can choose it’s dimensions. It was well worth the $50.
  • Sean Oneil
    May 29, 2007 at 5:08 pm
    Quicktime Pro will do this for you. Just open it up and export it to whatever you want.
  • Brian Pitt
    May 29, 2007 at 6:33 pm
    Are you kidding me? Why didn’t somebody tell me this earlier? lol! My quicktime won’t open the swf file. Do you know where to get the plugin?
  • David Roth weiss
    May 29, 2007 at 6:41 pm
    Brian,
    What Sean left out is that QT Player only plays Flash MX, not the most recent (and only good version) Flash 8. If you want to play Flas MX in the QT Player you must open the QT PLayer Preferences and check the Enable Flash box.
    David
    David Roth Weiss
    Los Angeles
  • Craig Seeman
    May 29, 2007 at 6:47 pm
    With the free Perian plugin installed you can play FLV8 in Quicktime. With QuicktimePro you may be able to export this to the .mov codec of your choice but I haven’t tried that yet.
  • Brian Pitt
    May 29, 2007 at 6:54 pm
    I’m still having trouble opening swf files in quicktime. I downloaded perian and I checked the flash box…any other ideas?
  • Parker Gowan
    May 29, 2007 at 9:13 pm
    You could try recording the video using snapsPro X. Doesn’t work very well with files longer than a couple minutes, but it works, will record in a quicktime compatible format…
