Activity Forums Adobe After Effects can wave world ripples fade before reaching layer edge
  • can wave world ripples fade before reaching layer edge
    Posted by Ste Hardy on January 22, 2013 at 9:34 pm
    Hi all,
    I wondered if Wave World ripples can fade before reaching layer edge.
    I thought I could do it by animating damping up to 1 but that is not working.
    also I would like there to be several concentric ripples but only 1 central splash, as if a stone or raindrop has hit the water. does anybody know if this is possible?
    thanks in advance
    s
    Darby Edelen replied 13 years, 8 months ago 4 Members · 3 Replies
  • Kevin Camp
    January 22, 2013 at 10:09 pm
    i assume you are using the resulting wave world ripple as a bump map (or displacement map).
    if so you can force the edges to go gray a number of different ways… to do it all on one layer, try adding the circle effect, click the invert circle option, set the color to 50% gray, adjust the radius and feather properties until the waves fade out as the reach the edges.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Vishesh Arora
    January 23, 2013 at 9:57 am
    ste
    If you are using wave world as a displacement map then
    precompose the Wave world.
    Now make a circular mask till where you want the waves to appear and again precompose it.
    Now use it as a displacement map.
    It may help.
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    2011 3D Demo Reel:
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • Darby Edelen
    January 25, 2013 at 5:00 am
    [ste hardy] “I thought I could do it by animating damping up to 1 but that is not working.
    also I would like there to be several concentric ripples but only 1 central splash, as if a stone or raindrop has hit the water. does anybody know if this is possible?”
    A constant Damping value should work for you. What that constant is will depend on a couple of other properties.
    The property you’ll want to animate for the single splash is the Amplitude of the producer. Animate this from 0 to 0.5 (or some other value) and back to 0. In general for a single splash I’d do this over 3 frames (frame 1: 0, frame 2: 0.5, frame 3: 0).
    The amount you set your Damping to will depend on the value you entered for your Amplitude as well as the Wave Speed and the Ground Height. I found that 0.5 was a good value for Damping with all other settings at their defaults and the 3 frame animation of the Amplitude.
    In addition you’ll want to feather the edges of the solid to 50% gray to be sure following either Kevin or Vishesh’s direction.
    Darby Edelen
