Activity › Forums › VEGAS Pro › Can u render 16×9 to 4×3 ? Can u render HiDef to Standard Def ?
  • Can u render 16×9 to 4×3 ? Can u render HiDef to Standard Def ?
    Posted by Will Standley on January 10, 2006 at 1:36 am
    1 – If I shoot in 16×9 and leave content in the middle (4×3) area…
    Will Vegas let me whack off the ends so that I can render the mid-section to 4×3 ? Or do you have to squish it or what?
    2 – If I shoot in HiDef… will Vegas let me render to either HiDef or Standard Def?
    3 – If I use two mic’s… one to the left channel and the other to the right…
    Can I take the Left Channel of Audio and add it to the Right Channel… (L+R) so that both mic’s come out of both speakers?
    Thanks for any help.
    Edward Troxel replied 20 years, 8 months ago 3 Members · 2 Replies
  • Peter Wright
    January 10, 2006 at 1:47 am
    Yes to everything!
    1 & 2. Select the appropriate Template when rendering
    3. Right click / Channels / combine
    or, if you want more control,
    Duplicate the audio track.
    On one track right click / channels / left only
    On the other track right click / channels / right only
    You can then control the relative volume and pan properties of each.
  • Edward Troxel
    January 10, 2006 at 2:25 am
    1. Yes
    2. Yes
    3. Yes
    And Vegas is great at changing between the various formats and is better than all other NLE’s when it comes to audio.
    Edward Troxel
    JETDV Scripts
