Activity Forums Audio can this recording be saved?
  • John Fishback
    March 6, 2015 at 10:26 pm
    I couldn’t download either of the clips. From your description I think iZotope RX 4 Advanced (maybe even regular old RX4) would be able to remove the beeps. It’s fairly straight-forward. But it’s a manual selection for every beep, so a bit time consuming.
    John
    MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.9.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCP-X 10.1.3, Motion 5.0.7, Compressor 4.0.7
    FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
    Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
  • Lara Michaels
    March 6, 2015 at 10:40 pm
  • John Fishback
    March 7, 2015 at 5:19 pm
    The challenge with iZotope will be to identify the beep in its visual display since it’s very soft. However, it would appear as a fairly straight line at its frequency. Here’s a page at izotope.com that shows a number of ways it can be used yo remove unwanted sounds. RX4 would probably do what you need. https://www.youtube.com/watch?v=apjW0xx5gnk&list=PL4dISychPQEsVXsFe5gwnes8fr7nuEvgH&index=9
    However, as the beep seems to be a particular frequency and not very loud, you might be able to use a parametric equalizer to remove most if not all of it – without hurting the dialogue. Apply a parametric eq to the clip. Then, adjust the Q to a narrow range and boost the gain a lot. Then, play the clip and sweep the frequency control until the sound of the beep is at its loudest. Then, further adjust the Q and frequency settings to maximize the beep. Finally, turn down the gain until the beep is greatly reduced or eliminated. The narrower the Q the better, as a narrow Q would least impact the dialogue.
    John
  • Lara Michaels
    March 8, 2015 at 8:06 pm
    Thank you so much for, John. I will try that.
  • Evan Allen
    June 10, 2015 at 5:25 pm
    Hi all!
    In the case where it’s difficult to visualize the particular audio issue in RX, there’s a few things that might help:
    First it might help to change the brightness of the spectrogram, by clicking and dragging the “dB” bar to the right of the screen.
    Second, if you’re dealing with beeps, it might help to switch the Spectrogram type to Adaptively Sparse, which is good for identifying harmonic content (like beeps!). The option to change Spectrogram type can found by right clicking on the spectrogram and selecting “view Spectrogram Settings.”
    And third, changing the Color map (also in the “view Spectrogram Settings” option) to one of the Multicolor options might help better highlight the problem!
    Best,
    Evan Allen
    iZotope, Inc.
    https://www.izotope.com/postproduction
