Activity › Forums › Adobe After Effects › can this be done in AE or other?
  • can this be done in AE or other?
    Posted by Jason Zaloga on June 23, 2011 at 10:03 pm
    i saw this video and was wondering if it was done in AE or a plugin or a 3d import.if it’s done in AE any insights on how it was done. i thought maybe it was nodes by yanobox or something.
    thanks
    Jason Zaloga replied 15 years, 3 months ago 3 Members · 4 Replies
  • Greg Burrus
    June 23, 2011 at 10:31 pm
    I would guess that if this was done in After Effects it would be done with an expression that calculates the distances of the end points to adjust based on where the middle circle is. I’m pretty sure I’ve seen something done like this before. There might be a plugin or script for this though I can’t recall any.
    It seems like something that you would see done in flash but it can be done in some way in other programs like cinema 4D.
    If you wanted to try and achieve this I would check out some expression tuts or check out the expressions forum here or at https://aenhancers.com/
    Hope that helps
    Greg
    https://mogra.g2bproductions.com/ – Blog
    https://g2bproductions.com/ – Portfolio
  • Greg Burrus
    June 23, 2011 at 10:37 pm
    I just checked out Yanobox and that seems it would be perfect for that effects and it works in After Effects. I’m going to have to download the trial and check it out.
    Thanks for sharing that!
  • Tudor “ted” jelescu
    June 24, 2011 at 6:29 am
    You can use the Beam Effect. Here’s a link to a thread that may help:
    https://forums.creativecow.net/readpost/2/944332
    Also, tis amazing script can help:
    https://ik.duduf.com/
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Jason Zaloga
    June 24, 2011 at 7:08 am
    tudor.
    the beam effect and 2 nulls was what i was looking for.
    thank you
