Activity Forums Zaxwerks Can the dock panels problem be solved?
  • Can the dock panels problem be solved?
    Posted by Ken Latman on March 28, 2008 at 3:21 pm
    I routinely forget that ProAnimator still has a little quirk if you don’t have the panels docked in AE that you get some weird processing slowness an inability to use the plug-in properly without switching between other programs and back to AE.
    Is this an issue that can be fixed in the next release of ProAnimator?
    I have two monitors and I usually have the Render Queue panel and Info panel on the secondary monitor. For the time being I just set up another workspace preference and activate that, when I know I will be working in ProAnimator plug-in. This tends to work.
    Ken Latman replied 18 years, 5 months ago 2 Members · 2 Replies
  • Matt Rhodes
    March 28, 2008 at 4:34 pm
    Hi Ken.
    This should be fixed with the next generation of the software — it’s being worked on now.
    We realize it’s a hassle having to dock everything in AE, but we just couldn’t get our dual-modal dialogs to work properly when panels were undocked.
    Thanks.
    Matt Rhodes
    Zaxwerks, Inc.
  • Ken Latman
    March 28, 2008 at 5:01 pm
    Thanks Matt. Look forward to it.
