Activity › Forums › Blackmagic Design › Can the decklink hd pro card capture HD 720p at 23.98??
  • Can the decklink hd pro card capture HD 720p at 23.98??
    Posted by Mark Linthicum on April 7, 2006 at 2:10 am
    I have a project coming in that was shot with the JVC HDV cameras, I plan to come out of the JVC deck analog HD to HDSDI via the AJA HD10A HDTV 10-bit Analog to Digital Converter into the blackmagic card then into Final Cut Pro.
    Has anyone done this?
    Any reason why it will not work?
    Thanks, Mark
    Kaspar Kallas replied 20 years, 6 months ago 2 Members · 3 Replies
  • Kaspar Kallas
    April 7, 2006 at 4:39 am
    this will not work – use the builtin(deck) upconvertor to get 1080
    -kaspar
  • Mark Linthicum
    April 7, 2006 at 5:21 am
    [Kaspar Kallas] “this will not work – use the builtin(deck) upconvertor to get 1080”
    So it will work? The deck can up-res to 1080? the decklink hd pro card will not do 720?
    Mark
  • Kaspar Kallas
    April 7, 2006 at 9:02 am
    it will do 720p just 60fps only @ 23.98 the stream out of the camera will be 60i (yes I know its perverse) it 60fps steram with 3:2:3:2 pulldown
    if ya figure a way to remove the pulldown you should end up with 24fps – but then you don’t have anything to montor your timeline with.
    I am testing this camera with FCP as we speak 😉
    -Kaspar
