Activity Forums Avid Media Composer Can the Avid make a video change list?
  • Can the Avid make a video change list?
    Posted by Jim Thomson on August 5, 2008 at 10:25 pm
    I’m assisting on a 2 hour project that was shot and onlined in 4:4:4 that will be recut. What I’ve done in the past is load a check tape from the online and add the video and sound tracks to the timeline top layers so changes can be tracked and the 1st online used as a source in the 2nd. However, when working in film, after the negative has been cut, the editor can still work only in dailies without the need of reloading the version that was cut as filmscribe can track the versions and deliver a change list. Is there any way to do the same in video, without loading dummy film information and using filmscribe? Is there anyway to do do this with sound? We are on a Mac based Adrenaline running v2.8.3.
    Job Ter burg replied 18 years, 1 month ago 2 Members · 1 Reply
  • Job Ter burg
    August 6, 2008 at 6:00 am
    The way to do this with sound is called Virtual Katy. Input an original EDL and a new EDL and VK will update a PT session.
