Activity Forums Compression Techniques Can someone suggest how to prepare a video with these specs: 3840 x 1080?
  • Can someone suggest how to prepare a video with these specs: 3840 x 1080?
    Posted by Thackston Addy on October 4, 2015 at 9:00 pm
    Hi!
    The final output is for a large video projection. Specs provided by Clear Channel Airport. Full specs attached.
    I’m working in Premiere CC. My source footage was shot at 1920 x 1080 and I’m editing native. or rather I have been on the rough cut. Not sure how to go about achieving the following output and placement.
    They want:
    thanks in advance.
    Ivan Myles replied 10 years, 9 months ago 2 Members · 1 Reply
  • Ivan Myles
    November 18, 2015 at 11:49 pm
    Set the sequence to 3840×1080 and scale the footage 200%, or
    Set the sequence to 1920×540 and set the output dimensions to 3840×1080 when exporting.
    The easiest way to create the 640×1080 black bar is using the Title function to insert a black rectangle on the uppermost track in your timeline. Alternatively, you could crop each clip, but this becomes troublesome if the video is moved.
