Activity Forums Adobe After Effects can someone explain to me how to make 2 layer stick together? parenting doesnt work with this
  • can someone explain to me how to make 2 layer stick together? parenting doesnt work with this
    Posted by Adam Bal on March 27, 2017 at 1:56 pm
    Hello ,I checked the forum and to make 2 layer move together, everybody recommends parenting. Which is a great tool, but however i have a really simple animation I couldn’t figure it out how to make a really nice smooth move.
    use case:
    layer one ( cropped picture moves from left to the right, stops, then moves again, stops, then move out. What I want to achieve is there is a slightly larger image layer 2, and it should act like it pushes layer 1 out of the frame from the left to the right. If I just do parenting since it has the different size the gap between pictures changing during animation. If I adjust it by hand it also ugly. Is there any way to set somehow the gap between layers to a certain value? or somehow forcing after effects to make the 2 layer syncronised? ( as there will be layer 4, layer 5 etc so it will be a huge headache to do it manually ( besides being ugly)
    Richard Garabedain replied 9 years, 5 months ago 2 Members · 2 Replies
  • Adam Bal
    March 27, 2017 at 2:17 pm
    Hello Dave,
    thanks for the reply.
    you say i must do it frame by frame?
  • Richard Garabedain
    March 27, 2017 at 3:45 pm
    parnent layer 1 to layer to, then check the position of layer 1 and hit zero in the z coordinate. then..move it to where you want..your problem is where in the timeline you parented your layers.
