Activity Forums VEGAS Pro Can someone explain the workflow with Izotope RX2
  • Can someone explain the workflow with Izotope RX2
    Posted by Ron Whitaker on March 18, 2013 at 11:45 pm
    Can someone explain the whole process they’d use to get rid of background hums with Izotope RX2?
    I’ve tried the trial version and if there’s some hum at the beginning of the file, I’ll have Izoptope “learn” the hum sound and it does an excellent job getting rid of it once I click the Process button.
    But, after that, if I highlight the entire sound file, then click Process again, all it does it take the entire audio, including the person talking, down to a muffled, inaudible level. The audio file is useless at that point.
    What am I doing wrong?
    Alexey Lukin replied 13 years, 6 months ago 4 Members · 5 Replies
  • Steve Rhoden
    March 19, 2013 at 3:20 am
    No, no, no,…You dont click the process button after you
    allow RX to learn the Hum. After it learns it, disable Learn
    and THEN highlight the entire track and click process.
    In certain host, you close it after it learns, then reopen it then
    highlight the entire track, then you process.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-832-4956
  • Ron Whitaker
    March 20, 2013 at 12:16 am
    How do you disable learn?
  • Ron Whitaker
    March 20, 2013 at 12:48 am
    Ok. I think I got it!
    I actually watched a quick tutorial online and this English guy used the Denoise feature.
    I followed his steps and it works beautifully!
    No more hum in the background!
    So, how much does Izoptope RX2 cost? Any good deals out there?
  • Roger Bansemer
    March 20, 2013 at 1:34 pm
    There is a great tutorial on izotope at:
    https://www.sonycreativesoftware.com/izotopewebinar
    and a bunch more at:
    https://www.youtube.com/playlist?list=PL4dISychPQEt04pe2EFaPRHe_477PZWdW
    Roger Bansemer
  • Alexey Lukin
    March 25, 2013 at 7:30 pm
    Hum Removal module is just a set of notch filters. If they muffle your audio too much, make sure that their frequencies and Qs are set correctly. Perhaps your Q is too low and filters cut too much material around the hum. In many cases, use of the Denoiser module is more justified for hum removal, as its adaptive filters can sense the presence of speech and accordingly control the amount of reduction.
