Activity › Forums › Adobe Premiere Pro › can proxies be relinked automatically to DNG sequences?
  • can proxies be relinked automatically to DNG sequences?
    Posted by David Baud on August 27, 2014 at 11:49 pm
    Premiere Pro CC 2014 (v8.0.1) is able to relink a proxy file (Quicktime files) to a DNG image sequence, but so far I have to do it one proxy at a time! I’ve got 300 image sequences!
    Is there a way to have Premiere automatically relink proxies to DNG image sequences all at once?
    David Baud
    Post & VFX
    KOSMOS PRODUCTIONS
    Denver – Paris
    http://www.kosmos-productions.com
    Tero Ahlfors replied 12 years, 1 month ago 2 Members · 3 Replies
  • Tero Ahlfors
    August 28, 2014 at 5:59 am
    You’ll need to select the correct attributes in the link media window. If the proxies were made correctly they should share most/all metadata that the DNG sequence has. The file extension doesn’t match so you should tick that off at least.
  • David Baud
    August 28, 2014 at 3:27 pm
    Thanks Tero. Right now (in the Link media window pane) I have tried with File name checked and all the others unchecked:
    . File extension
    . Media Start
    . Tape Name
    . Clip ID
    With that configuration Premiere is not able to relink automatically.
    I have Align Timecode, Relink others automatically checked as well.
    To give you an idea here is an example of a proxy file:
    140328-OdysseyCLIP0000034.mov
    Here is the corresponding original Cinema DNG images sequence
    folder name:
    inside of this folder first DNG file starts like this:
    140328-OdysseyCLIP0000034_0000000.dng
    140328-OdysseyCLIP0000034_0000001.dng
    140328-OdysseyCLIP0000034_0000002.dng
    etc…
    I was not involved in generating the proxies so I am hoping the metadata are the same. I am just wondering if Premiere is capable to recognize automatically images sequence.
    Do you know what Media start means? isn’t it similar to timecode information?
    Thanks.
    David Baud
    Post & VFX
    KOSMOS PRODUCTIONS
    Denver – Paris
  • Tero Ahlfors
    August 28, 2014 at 6:00 pm
    If the clips have unique timecode and/or tape name you should try toggling those.
